95 ATX running like crap?
jmpSHO
Massachusetts
I cleaned my motor today with degreaser and water and now it runs pretty bad. I am going to scan it in a few. I suspect the VSS as one of the problems but I am sure there are others. It revs pretty high and sometimes it will come out of third and rev up. If anyone has any input I would really appreciate it.
jmpSHO
Massachusetts
Here are the codes, I just scanned it so I haven't had time to look up all of them. I will clear it tomorrow and see what pops up again.
KOEO: 335 & 522
Memory Codes: 189, 212, 214, 336, 634, 659 (have never seen that one)
jmpSHO
Massachusetts
Also not sure if it means anything but I couldn't get my scanner to perform the KOER test.
jmpSHO
Massachusetts
So today I pretty much disconnected every connector under my hood and dried everything with my compressor and reconnected everything. Alot of the codes went away but the 2 that I have 522 & 634 (I think they are related) are what is making my car shift like crap. The only problem is I am not sure what the sensor is called, I think it's called the transmission range sensor or position sensor switch. Does anyone know the correct name for this.
shonuffmine
wildchild
sweating balls in fla.pan
I did the same thing last weekend,i sopped all the water outa the plug wells ,that got rid of the dropped cylinders then just drove it 40 miles down to Bangor then 40 back,it ran all goofy (tach would drop out then come back,weird idle n so forth) Once she got hot enuff n evaporated the water it was all good!
jmpSHO
Massachusetts
I drove mine for about 2 days and over 100 miles and I am pretty sure i messed up some sensor that is related to the transmission.
tinkerkathleen
