Factory Keyless Entry Code
blownsho94
Pennsylvania
Hi all,
The factory keyless entry code does not work! The usual last two buttons for lockng does, however, the factory code does not unlock the doors! Any advice?
blownsho94
Pennsylvania
I assume you're using the code you found somewhere in/on your car (ie: trunk, owner's manual) and not some code you found online. Correct?
edit - I'd also like to suggest you do a quick read of this thread: http://www.shoforum.com/showthread.php?t=91809
Yes, the code is on the trunklid support. The thing is, the 7/8, 9/0 buttons lock the doors as intended but...... I cannot get the dang thing to accept the code!
Rubix
When you approach the car and press a button (other than 7/8 or 9/0) do the interior lights come on? You might have a faulty keypad.
Maybe the trunklid is not the original one but rather one from a different car.
1993MTXSHO
Its a Taurus...
Jersey
That's probably the issue, press each button and make sure each one lights the interior lights. If they all do, go to the keyless box in the trunk (not the number on the trunklid) and see what the actual code is on the box then try again. My trunklid codes do not match any of my keyless boxes as I change every one of mine when I get a "new" sho, then I rip the sticker off the box in the trunk too, so hopefully someone didn't do that to yours.
89SHOMAN666
SHO NUT!
Reading, PA
Paranoid Bast***d :rockon:
