???? I was thinkin!!! I wonder if my drag wheels will fit???
beefcake
cincinnati, ohio
the more i think about it, it's the same bolt pattern. I gotta think the 17" front alumastars oughta fit for sure, if they can clear an 03/04 cobra brake right?
i don't know about the rears though, being 15" with that suspension they'll probably hit
anything for a 12 though lol
maybe i'll test fit tonight
other questions is, how much power goes where?????
who knows??
will the skinnies just spin. gotta be a **** of a weight reduction off the front
Racer X
SHO Pilot, Retired
Connecticut
If the wheels are different diameters between front and rear, the AWD system is going to have a fit.
If it doesn't break outright, that is.
beefcake
cincinnati, ohio
yeah, if the overall height is not the same, that'll be a problem, didn't think about that
the 20's are prob 28" tall and i know the skinnies around around 26", wouldn't work unless the slicks would clear too
beefcake
cincinnati, ohio
:stupid:
It aint gonna make it any faster with sticky tires. IT's already AWD and weighs 4000lbs.
this isn't my first go round down the dragstrip.
weight is everything, every 10lbs of rotational weight you pull is like pulling 100lbs of fixed weight off the car to a certain point.
if you can pull 20-25lbs off each front tire and 15 or so off each rear, your talking about pulling 70-80lbs of rotational weight
that could easily translate into 2-3 tenths maybe more :thankyou:
tardboy21
Woodbridge, NJ
if the diameter of the tires is different, won't the AWD always think the smaller pair is slipping. :shrug:
where are the sensors that control this?
they will be rotating at a quicker speed than the larger set. How it will adjust is a good question. Would putting a little bit bigger tires on the back cause the AWD to try and put more force to the back wheels?
try it out and let us know if something breaks.
:theyareontome:
pitaSHO
Why do I do this to myself?
Lewisville, TX
To OP. Do you have a 10 FT SHO or a 2010 SHO? Hyphen's in the wrong spot in your sig pic, dude. :laugh_ti::laugh_ti:
Chris K.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Thanks for the unneccessary explanation, but its not my first rodeo either.... :swing:
You aint gonna get 2-3 tenths that way.
beefcake
cincinnati, ohio
if you don't think knocking nearly 100 pounds of weight off your tires will get you at least .2 then you can't have done much serious racing
100 lbs of fixed weight should get you .1 rotational that will at least double, at least
SHO U UP
SHO Guru
Virginia Beach, VA
Dude, if this guy has a Termi and has been to the track, then he basically knows his stuff. Being a fellow SVT owner, I can vouch for shaving off weight bro. Lose some poundage on that SHO and let 'er ass eat! Then, like the other guy(s) said, let us know what breaks. Good luck beefcake, BEEFCAKE!!:rofl:
kikkinasphalt
Wrrrrrrrr
Missouri
hmmmm
how many sun 12 second cars have you had?
funnay
stock wheels on my z28 DR's - 11.30
draglights on my z28 with DR's - 11.31
back to back passes
i doubt you will pick up 3 off the wheels. but if you do.. cool
afwiw St Louis SHO has spent plenty time on the tarmac
SHO U UP
SHO Guru
Virginia Beach, VA
how exactly do you figure losing weight doesn't convert into a lower time...? :huh:
Uh, I hope you aren't directing that to me there bro. I'm agreeing with the guy for crying out loud. :rolleyes: Maybe you're asking that other guy. Yeah, that's gotta be it.....
beefcake
cincinnati, ohio
hmmmm
funnay
back to back passes
how many 12 sec cars, not too many to be honest with you.
i did have a 99 cobra than ran 10.50's
and an 01 lightning that ran 11.8's @ 5200 lbs, oh yeah, and i won 4 national events with that one back in 02 and was featured on espn a few times
then there was my 90 s/c gt that ran 11.9's
oh wait, then my 04 cobra than went 11.2's
shit i forgot, then i had my other 01 lighning that ran 10.7's at around 5100 lbs
lets see what else, oh yeah, my 06 gt than ran 11.9's, then there was the 08 gt500 after that, i think it went 11.17's, then my 08 corvetter that went 10.8's, then the 04 mystic cobra i just sold that went 11.0's.
oh yeah, and the 2 hayabusas than went 9.9's, to 9.8's, and lest we not forget the turbo hayabusa that went 8.6's.
so your right, no 12 sec cars
beefcake
cincinnati, ohio
right click and save as
http://beef-cake.net/beefcake1051.mpeg
10.8
http://videos.streetfire.net/video/Beefcake-run_641181.htm
the 10.9 the car sounds better here though
http://videos.streetfire.net/video/Beefs-1093-run_641218.htm
http://www.youtube.com/watch?v=ypOH5aOBBsY
here is the 10sec lightning, it went 10.9's driving it to the track on dr's, it was pretty sick, built motor, stage 3 heads and cams, ported blower @ 16psi plus 100 shot, no vids though. i removed the factory interior and put in corbeaus, and then tapped the holes in the floor and put an expedition console in (the expy's have the same chassis, so the holes were there, just needed tapping)
this is all i could dig up real quick, maybe i'll find some more later
beefcake
cincinnati, ohio
hmmmm
funnay
back to back passes
found a couple of espn vids
here was an interview they did with me
right click and save these please
http://www.svt-lightning.com/richmedia/espngeorgia.mpg
here is another win on espn
http://beef-cake.net/espnmaplegrove.mpg
and another
http://beef-cake.net/espnms2002.mpg
this was a nice one from that same race
http://beef-cake.net/2002modshootout.mpg
maybe i can join your club now kik
hawkeye18
Sorta cares
Norfolk, VA
It is. Don't worry about it lol.
it du.
but going to lighter wheels isnt likely going to net him 3 10's
Now that I can agree with. It's not impossible, just highly improbable.
Brad kirk
