poor mans forced air?
mattsho1993
SHO owner
albion, new york
so i had an idea a few years ago but found a video... someone else thought about it to lol ok don't laugh you know a leaf blower how they make them to blow as high as like 250mph well what if you hot wired it and fit it to your intake? obviously it'd give you a hp gain but will it hurt my sho 1993 mtx?
illSHOyou
Troy, MO
Nope, shouldn't hurt it, but is it practical...? and will it support the engine to redline or become a hindrence half way in the rpm band...?
I thought of a neat idea about a electric blower (A custom built unit from model airplanes) that I think could work. I wouldn't talk about it on this forum, its against peoples religion, trust me I know...
1bad98SHO
Fayetteville, N.C.
From what has been gathered it will not work. Forcing the air into the engine without compressing it will not do much good. This is why a Turbo Has a Compressor Side which Compresses the Air as its drawn into the Turbo. This is why Turbo cars need an intercooler. The Air that gets compressed gets pretty hot from the actual compression.
So in theory it sounds like a good idea but in reality its not.
mattsho1993
SHO owner
albion, new york
i think it'd be like a electric supercharger on crack lol there are videos of dyno test with small blowers but i was thinking a monster one
somedude_001
Western NY
I did this on my saturn just for kicks to see what would happen. the leaf blower I was using was gas and made 0 boost when the engine was at idle but once the engine hit about 4K I was running 4psi of boost and it held that to redline. The leaf blower compressor needs flow to be able to compress air other wise it cavitates and essentially does nothing. with a tweecer and some tuning you could potentially gain about 50hp from this and you could use you stock fuel system to do it. the only problem you will come across is mounting a leaf blower. They are kind of big, we took the hood off my saturn and used a liberal amount of duct tape to make it happen. and unless you already have a tweecer and a leaf blower it will be cheaper, yield much better results and be a **** of a lot less embarrassing to use a product designed to achieve the results you are looking for.
