Panting Valve covers?
bubba
ATX Connoisseur
Fort Wayne, Indiana
I have a pair of pretty stained up valve covers! and wanted to see what people used to sand them down..... I know a lot of people like the PC'd but I want to do it with paint to see how that come out! I have sand paper and all just seeing what grit people use on them is all!
Brett
SHOs before HOs
Minnesnowta
I am not impressed with the high temp paint they sell at advance auto and such. I took a long time with prep, cleaned them very well in a parts cleaner and out, sanded them etc. etc. It chips VERY easily. Someone here, i think kdawg has said hes used exterior truck paint or something? He said it holds up pretty well. Someone also said to use seran wrap to put everything back together to prevent scratches/chips. Good luck.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I've done both painted, and PC'd. Personally, I'd go with the PC. After enough heat cycles, the painted ones tend to fade and become dull over time.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Colors are going to be limited, but Duplicolor wheel paint does fantastic as intake and valve cover paint.
Mine had more than 50k and 6 years on it. No fading, no chips, just look'in good.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
That does look good. Is that a recent picture?
whiteman_01
Well-Known Member
Hastings, MN
I used the duplicolor truck van and suv paint. It seems to be holding up well. I did chip it though putting it back together with the handle of my ratchet.
firebat45
Edmonton
POR-15 is rock hard stuff once it cures. The engine enamel will be more than fine for intake/valve covers, the normal stuff might even be okay. It comes in a few colors, not tons but enough to satisfy most. The important part is the prep, it works best when the metal is etched/sandblasted/slightly rusty.
bubba
ATX Connoisseur
Fort Wayne, Indiana
Yeah, I have self etching primer and stuff like that! I just need to know the grit size it use! I was looking at getting sandblasing them, but I won't lol
walser
new ulm MN
your gonna want to sand blast them.. i did and before i powdered them i sprayed them down with brake cleaner to make sure all the oil from my hands were off. i would recommend sandblasting them
Shopower400
Atlas
Electric City, NY
I used high temp engine paint. It works great for the intake, but when i used it on the valve covers, they went from silver to a 'sand/bronze' color. I think they get just a little hotter than the intake, but that's just my guess.
If i were to do it from scratch, i would paint the intake, and PC the valve covers. My buddy paid $300 just for the valve covers. I did my entire intake for under $30...
Larkin660
Derry
I used Duplicolor engine enamel on my intake and it came out fine. a chip or two putting it back together but nothing too bad. been driving it for hours in 100 degree heat and it hasn't effected it at all. even used sharpie pen paint to fill in the SHO 24 VALVE DOHC part and thats still perfect
walser
new ulm MN
eastwood makes an awesome powdercoat kit, just need an oven, it works awesome and is still very durable for $170 kit with 3 samples of colors, i used it on mine and is holding up perfect
Westerly, RI
A few tips, I've painted three intakes and two sets of valve covers over the years with good results.
-If you can at all afford it, get them sandblasted. Much less time consuming, and you'll have a better surface to work with.
-If you can't find an affordable sandblasting outfit, or don't want to sandblast them, sanding will still give OK results. Make sure you degrease the **** out of them first. I've had good results with Castrol Super Clean (or something like that, it's in a purple bottle). I use those cheap horsehair paint/chip brushes to scrub with, and rinse well. After that is done, you're going to want to use some sort of solvent to make sure the finer oils are gone. Brake cleaner may be too harsh and take the original paint off, making for a total mess to try and sand. I would stick with something like denatured alcohol.
-If sanding, you won't need to get everything down to the bare metal. Just scuff it enough for the new paint to have a good base to adhere to. In fact, you might find that using some rougher grit scotchbrite pads will be a lot easier. They conform to the irregularities of the surface better. You won't need to use etching primer if you're not going down to the bare metal. Any old primer will do in this case. Shoot a couple good coats of primer, and then you can start your color coats.
-I used Duplicolor wheel paint in the charcoal color on my valve covers 3 years and 60k miles ago, and it still looks like the day I did it. I used their wheel clearcoat over the charcoal as well. If you use this stuff, make sure you follow the timelines given on the directions on the can. If you wait too long/not long enough to spray the clear it will wrinkle the color coat. I used some fine scotchbrite in between coats for a nice smooth surface.
-On my intake I used Duplicolor metallic paints, with their regular crystal clear coat spray. This intake has only been on for about a month, but it's been through quite a few heat cycles and still looks great. Again, scotchbrite between coats made for a nice finsished surface.
The important thing to remember is prep. The more time you take to prep correctly, the better your results will be. Also, any paint will chip if hit hard enough. If you're painting these parts, you have to expect chips at some point, and know you'll have to fix them. I scratched the **** out of my intake putting it back together, but touched it up with a small brush and you can't even tell it happened. Powdercoat will also chip, if hit hard enough.
Good luck with the project!
bubba
ATX Connoisseur
Fort Wayne, Indiana
Thank for you the input..... I thought I should hit it with some rougher grit. I will post some after there done!
