Marccus
1989 w/(about) 440K.
Upon a cold start (car left for more than 4-6 hours, overnight), the start is very rough, with a "rolling idle" (as Ford describes it). I have to chase the tach up and down so it won't stall. If it does stall, it is VERY difficult to start. After about 5 to 10 minutes the engine idles like it is new and can drive with no problem.
If I leave it for more than 4 - 6 hours, then it's back to the same problem. Less than 4-6 hours it starts fine with a perfect idle.
I've been chasing this for months. There are no trouble codes and today I got code 67, which is a NPS for the A/C which should have nothing to do with the starting problem.
I've replaced the IAB valve like three times in the last 2-3 years.
Cleaned the throttle body and MAF.
Replaced coil about 1 year ago.
Replace TBS about 2 years ago.
PS pump replaced 5 years ago.
Intake manifold cleaned and rebuilt about 8 months ago.
New fuel pump - 4 months ago
New water pump - 6 months ago
CPS, CKP, timing belt, PS belt, WP belt - 6 months ago.
Cannot detect any vacumm leaks.
[U]Slight Coolant leak[/U] - loss of pressure about 1.5 psi over 5 minutes, cannot find leak with pressurized cold test and soap solution. Maybe radiator plastic tank leak. Radiator is over 8 years old.
Secondaries still not working. Checked wiring from PCM to connector and continuity is OK. Replaced the entire secondaries mechanism (solenoid, cannister, etc.) three times with units from junked SHOs. Highly unlikely that all three are bad. Still trying to figure out this problem. This problem existed before the cold start problems.
Fuel injectors never replaced.
Cold start problems began when catalyst in cat began rattling around and realized the cat was blown. Welded in new cat but problem persisted.
Perhaps blown catalyst worked its way down the exhaust resonator pipe and jammed leading to higher back pressure?
If so, why does problem clear itself up after 5-10 minutes after cold start.
Is there something the PCM does different when the engine is first started and "adjusts" engine to accomodate this problem.
For instance, upon cold start, PCM sees high back pressure caused by catalyst and adjusts engine operation to accomodate this to run smoothly.
Will be installing new cat back (w/o mufflers) from ShoSource within several weeks.
Any ideas??? :braincramp:
Any ideas??? :braincramp: .
