NEp8ntballer
cyber ninja
Vehicle: 2010 Ford Taurus SHO
Odometer: 2,289
Date: 06/16/09
Driver: Chris Walton
Price: $45,475
Specifications:
Drive Type: All-wheel drive
Transmission Type: 6-speed automatic
Engine Type: V6
Displacement (cc / cu-in): 3,496cc (213 cu-in)
Redline (rpm): 6,700
Horsepower (hp @ rpm): 365 @ 5,500
Torque (lb-ft @ rpm): 350 @ 1,700
Brake Type (front): Ventilated Disc
Brake Type (rear): Disc
Steering System: Electric power steering
Suspension Type (front): Independent, MacPherson Struts with stabilizer bar
Suspension Type (rear): Independent, multilink with coil springs and stabilizer bar
Tire Size (front): 245/45R20 99V
Tire Size (rear): 245/45R20 99V
Tire Brand: Michelin
Tire Model: Primacy MXV4
Tire Type: all-season
Wheel Size: N/A
Wheel Material (front/rear): Alloy
As tested Curb Weight (lb): 4,404
Test Results:
0 - 30 (sec): 2.4
0 - 45 (sec): 3.9
0 - 60 (sec): 5.8
0 - 75 (sec): 8.7
1/4 Mile (sec @ mph): 14.2 @ 99.11
0-60 with 1-ft Rollout (sec): 5.5
30 - 0 (ft): 31
60 - 0 (ft): 127
Braking Rating: Average
Slalom (mph): 62.9
Skid Pad Lateral acceleration (g): 0.80
Handling Rating: Average
Db @ Idle: 44.1
Db @ Full Throttle: 71.8
Db @ 70 mph Cruise: 64.1
Acceleration Comments: The SHO didn't respond (good or bad) to brake-torque, so best launch was at 2,000 rpm. Revs didn't fall (good) but things didn't really start 'till 3,000 rpm. Upshifts at 6,250 were smooth but not especially quick. Accel was linear until end of quarter-mile where it lays down a bit. (Smoking brakes after 5th accel run.)
Braking Comments: Gravely tire noises, moderate pitch, soft pedal goes nearly to the floor. So-so initial bite, good in the middle then soft at the end.
Handling Comments: (Skid pad) Chassis is slow to respond to steering input -- not at the sidewall level, but due to body motions. Understeers with maintenance throttle and lifting to get rotation awakens stability control. (Slalom) To keep from arriving late at each cone, I had to dial the speed down. Friction-free steering with mild load-up. Just as understeer begins, stability control starts grabbing brake, then throttle dips. Would be nice to turn off stability control, but you can't do that unless you get the optional performance package. That same package also adds better tires which would likely improve results.
Vehicle: Inside Line's Long-Term Pontiac G8 GT
Odometer: 2,675
Date: 06/16/09
Price: $31,845
Specifications:
Drive Type: Rear-wheel drive
Engine Type: V8
Displacement (cc / cu-in): 5,967cc (364 cu-in)
Redline (rpm): 6,900
Horsepower (hp @ rpm): 361 @ 6,300
Torque (lb-ft @ rpm): 385 @ 4,400
Brake Type (rear): Ventilated Disc
Steering System: Speed proportional power steering
Suspension Type (front): Independent, MacPherson struts, coil springs and stabilizer bar
Suspension Type (rear): Independent, multilink, coil springs, stabilizer bar
Tire Size (front): 245/40R19
Tire Size (rear): 245/40R19
Tire Brand: Bridgestone
Tire Model: Potenza RE050A
Tire Type: Summer performance
Wheel Size: 19-by-8-inches front; 19-by-8-inches rear
As tested Curb Weight (lb): 4,021
Test Results:
0 - 30 (sec): 2.3
0 - 45 (sec): 3.9
0 - 60 (sec): 5.8
0 - 75 (sec): 8.3
1/4 Mile (sec @ mph): 13.95 @ 101.3
30 - 0 (ft): 28
60 - 0 (ft): 113
Braking Rating: Very Good
Slalom (mph): 63.4
Skid Pad Lateral acceleration (g): 0.86
Handling Rating: Good
Db @ Idle: 48.1
Db @ Full Throttle: 76.9
Db @ 70 mph Cruise: 68.1
Acceleration Comments: Why is there no redline on the tach? Isn't this a sport sedan with a powerful engine? Bizarre, especially since manual mode holds gears and will bang off the rev limiter all day long. Quickest accel times came in Sport setting with transmission shifting on its own. There's very little wheelspin at launch.
Braking Comments: Some fade became obvious after 5-6 stops, but the distances continued to come down to a world-class 109 feet. Some ABS kickback is noticeable through the pedal, but the overall brake feel -- at least prior to the minor fading -- is confident.
Handling Comments: Transition to oversteer isn't as intuitive as I'd like. Perhaps this is due to minimal roll stiffness. Once the tail is out, however, the G8 GT is easily controlled. Little roll stiffness also means there's an uncomfortable amount of time between weight transfer in transitions in the slalom. Otherwise, handling is good with predictable limits. Oh, and stability control can be fully disabled.
discuss
