somedude_001
I logged 97 miles on the track in my 1990 MTX yesterday. What a beast this car is going to be once I get some of the kinks ironed out. Arrived to the track at noon and went through the driver meeting and then through tech, and then about 10 people were poking fun at me about it catching fire again or dumping oil on the track... so on and so forth. A first timer asked to go for a ride to learn the track and I agreed to show him the track. I have never driven the track without my R comp tires on and needless to say I over estimated the amount of traction I thought I had going through the long sweeping corner. the 4th lap I went 2 wheels off and the side of my car got all conned up. Pulled into the pits to inspect the car. No damage of course. I felt like a complete noob but the kid definitely appreciated what my car had in it after he went out in his car and felt that. "WOW I can't believe how much more grip your taurus has than my audi A4 in those corners"
I went out for another session to learn the line of the track better and I got behind a S2K that was going at a good clip. He certainly was not pushing his car super hard but he had a good line and I learned. About 10 laps in he signals me to pass. I step up my game and he was chasing about 5 laps later I was watching him instead of the braking markers and I failed to slow enough coming from the back straight into gilles. I sent the left 2 off again at the end of barack's because of this excess speed. So I pit agian to give the car quick look. No damage once again. I noticed that the outer edge is getting hammered on the front tires. So I jacked the front end up and loosened the strut towers and slid them all the way in for max camber. OMG what a huge difference. The car now has a very nice amount of oversteer off the throttle and when trail braking it seems to step out nicely.
So I managed to catch up to the very same S2K again and follow him for a few laps, and he signals me to pass. about 5 laps later I decide I want to whip the car into gilles at a insane speed and see if I can induce a pretty hard tail slide in hopes that I can ride it through barack's then power out. Well that was a good idea in theory but my car does not have nearly enough rear wheel drive to pull that off... or so I thought. My 11.6" brakes were no really up to the task of stopping this car so I decided to not use them as much and let the rear end swinging out slow me down. This was definitely the most fun I have had in a long time... scratch that. EVER in my SHO. I had been entering gilles at 50-55mph and now i'm entering in the 65mph range with the ass end completely out. I would brake a little then give a quick spike and give the wheel a quick yank to the right and WEEEEEEE.
As the day went on and the gas tank emptied the rear tires started to chatter a lot when the car was sideways. I asked nick (hotrodkid) to watch the car to see if he could figure out what is going on with this. It was starting to get really annoying because it was beginning to get kind of violent as I neared a empty tank of gas. He said that my rear tire looks like it is folding under the car like something is flexing giving my rear tire positive camber. After hearing that I jack up the car just to give it a good once over and to check bolt tightness for all critical rear end components. Everything looked perfect. So this leaves me with a couple of thoughts.
1. I have BMR rear lateral arms and a H-brace so I know those are solid.
2. maybe the strut towers are flexing a lot due to my lack of STB.
3. maybe it is the fact that I have 225/50/16 falcon azenis on 6" slicers and the tire is way to big for the rim. The possibility of massive sidewall flex is reasonable.
4. I remember reading something about a knuckle brace on shotimes. Maybe my rear knuckle is flexing under the massive load of sliding sideways on almost every turn all day. (I don't want to break it!)
5. too much ass hatting in a sedan not built for it. :wave:
at the end of the day I ran a 1.2X when we did the timed event. Which is not bad for street tires but I could have ran a **** of a lot better had I bolted my R comps on. nearly everyone else that ran the timed event was on race tires. fastest car of the day ran a 1.13 but it is not street legal.
quick walk thought the track.
Starting at turn 1 the padock. This is a low speed turn at about 40mph but about half way through club I am WOT in second and just before sunset swerve I shift into third and never let off the throttle through that turn. Full power down the back straight. quick whack of the brakes and stuff it into second gear coming into gilles, quick yank of the wheel sends me into gilles sideways at about 65mph. Quick blip of the throttle to settle the rear end then tap the brakes to **** some speed for barack's then back to full power in second gear. Into 3rd and take the kink at a unsettling speed and get on the brakes hard while still turning to get the rear end out for the carousel, and once the rear end is out I drop in into second and get back on the power and half way through the center straight shift back into 3rd. quick whack of the brakes and snap the wheel left and you take len's with the rear end slightly out (had problems with this turn all day) stuff it into second and hit the brakes for the upcoming right hander (also never got this corner down). This is a relatively low speed turn so the rear end was firmly planted with no sliding at all
most of the day I would not run the front straight hard because of my brake issues. I would hit about 6K in third about half way through the straight and maintain speed then lightly get on the brakes for the paddock. good time for sure! best 100 bucks i've spend in a long time! My upper body is really sore today! :laugh_ti:
