1993 Blk/Blk MTX - Very GOOD condition
pitaSHO
Why do I do this to myself?
Lewisville, TX
Up for sale is a black-on-black 1993 MTX. I bought it last August with the intent of restoring it, modding it, and keeping it forever, but I have since purchased a track prepped 91 Plus and can't keep all my cars (still have a gutted 89 and a wrecked 95 I want to fix again). It is a stripper model; no keyless, moonroof, passenger airbag, or power passenger seat. It has just over 197k on the ticker. I am countinuing to drive the car as my daily driver to help seat the ring in, so it will have more miles on it by the time of the sale.
Here is the history on the car since I have had it.
I bought the car with a supposedly bad motor. Long story short it ended up being a bad piston ring in cylinder 5. I pulled the motor apart, honed the cylinder wall, and replaced the piston. I re-used the rod, just to keep things as close to original as I could. The cylinder wall was not scratched at all. The parts I replaced:
Piston
Head gasket
Coolant crossover gaskets
All fresh O-rings on coolant tube between the water pump and back of engine
Injector seals
I also did a full front, top, and bottom 60k, which included
Water pump
Timing belt
Crank sensor
Crank seal (Ford)
Rear cam seal (Ford)
T-stat (Ford)
Lower radiator hose
Upper radiator hose
Temp sender
Oil pressure sender
Rod bearings
Valve lash adjustment
Spark plugs (Autolite Platinum)
Valve cover gaskets
New Autolite battery
Front cam chain tensioner (almost no wear)
The only thing I didn't replace were the wires. I had some good used aftermarket ones. I got cheap and ran out of money.
After replacing the piston I ran it for 100 miles and changed the oil with Valvoline 10W-40 and added a bottle of Auto-RX. I have since run it another 100 miles or so. The ring is still seating to the block, but the compression is getting better. It idles very smooth and does not burn any oil. The oil and coolant levels are stable.
The condition of the car is very good. The interior is almost mint. The driver's seat has almost no sign of wear and the dash is not cracked, but the EATC does have cracked buttons. The previous owner removed the stereo and I do not have one to replace it. The factory speakers are still there, but the factory amps have also been removed. The windows were at one time acquainted with tint, but the tint has been almost completely faded. The paint is in overall very good condition, and B being in the NW has saved it from any rust. The tires are almost brand new and the brakes have had recent work (I still have the receipts in the glovebox from the PO on the maintenance he had done). The slicers are near perfect with no curb rash on the wheels. The suspension feels original; worn, but not dangerous. It doesn't make any clunking sounds or anything, but it will probably need to be replaced at some point (kinda floats a little). Overall the car is pretty tight. There are a few minor blemishes on the exterior; I'm not advertising it as perfect, but they are very small.
The only thing I am aware of that doesn't work is the back left window. I'm not sure if it's a switch or the motor, but the window doesn't go down.
If you have any other questions, please let me know.
I'm asking $2300 obo.
Chris K.
Black93MTX003
Black93MTX006
Black93MTX015
Black93MTX019
Black93MTX020
Black93MTX022
Black93MTX025
Black93MTX027
Black93MTX028
JRA2000TL
The Complainer
Daphne, AL
Oh wow, so this is the one you were telling me about! Nice looking car man! I may be on hold for a few months though until I get mine. I just had to fork out alot of cash for my honeymoon trip and that money came out of my SHO fund. :mad: The black/black 93 MTXs are my dream SHOs.
Foamy
Alberta
Hot damn that is a great price. It turns out that I just sold my 99 for $3000 and I have always thought about buying a gen2. I will put some serious thought into it and let you know.
Irish Pride
Irish Inside
MusicCityUSA
why couldnt this car been white? everything i'm looking for in a SHO but the color. Good luck with the sale!
pitaSHO
Lewisville, TX
Updated pricing and delivery options
**PRICE REDUCTION**
New price is $2500. I may be getting into a house soon and would like to sell this car sooner than later. Also, Mike Stimson may be driving to the convention this year and has volunteered to drive the car to any destination between Seattle and New England if transporting the car is the issue. His handle is shopartsnw, and you can contact him directly to verify if he is going to make this drive.
Thanks.
Chris K.
JRA2000TL
The Complainer
Daphne, AL
Man, I wish you weren't so far away. I could fly out there and look at the car (I don't want to buy it sight unseen, though I could probably trust most people on here). That and I don't want to have to drive the thing 3000 miles home. I'm also not exactly "on the way" to the convention either.
I have a hard button EATC and a Gen II premium sound deck, so that fixes those issues right there.
I'm looking at 2 other SHOs and still trying to sell mine in the process, but this is on my list of possibilities as well.
Big D
YamaHAHAHAHAHA!
AK-Rowdy, OH
:salivates: looks great!
If I had the money i'd be mine.... that's my dream SHO!!!
Anyway, free bump!
pitaSHO
Lewisville, TX
I'm open to reasonable offers at this point. I have one person interested who really wants it, but I'd rather have cash than a good intention. I have put 400miles on the car since I listed it, and the ring is seating in nicely. When I replaced the piston/ring I couldn't drive the car unless it warmed up for five minutes or so. Now I can drive it cold, with a little coaxing. It still lacks some power, but it is improving. It could take 2-3k miles to seat the ring, but it's already much better than it was. There are no driveability issues with the car. It starts, runs good, idles good, and won't stall unless you dump the clutch. ANYway...
Chris K.
pitaSHO
Lewisville, TX
If distance is an issue I can deliver the car for a small fee. I'm only working part time because there's not a lot of drafting to do right now, so I have time to drive.
Chris K.
JRA2000TL
The Complainer
Daphne, AL
Why must you be all the way at the opposite side of the country?! Shipping would cost me an arm and a leg; plus I'd want to fly out there to look at the car in person before I made a purchase. Logistics make this almost impossible for me though. :frown:
pitaSHO
Lewisville, TX
Well, it's a well maintained SHO. The interior is in great shape, as you can see by the photos. The engine is still breaking in a ring, so compression is not yet fully restored. It would easily make the trip, but it lacks some power, and will until the ring seats, which could be another 2500 miles. It starts right up, runs great, never stalls, and has original suspension. It has the usual spounge effect of soft worn suspension, but should be fine for some time to come. I know some people are picky, but a 93 blk/blk MTX in this good of condition would be a prime candidate for a 3.2 swap. I also have a 3.2 with 179k miles that came from a good running car. I could throw that in for another $200 and all the new components from the 3.0 would swap right over. That's what I was planning on doing until I found my 91 Plus. I would be willing to drive it half way for $2800.
Chris K.
pitaSHO
Lewisville, TX
PRICE LOWERED... a little
$2300. I'm not desperate to sell, but it would be nice to reduce my collection. It's coming off registration and insurance in the next month or so. Delivery can be arranged.
Chris K.
pitaSHO
Lewisville, TX
Where in Arkansas are you? Delivery can be arranged. I have two friends from here in Washington that are driving to the convention that said they would be willing to meet anyone between Washington and New England. Just an idea.
Chris K.
