help asap
letmeshou
maryland
i hit 2 grand my light get brighter headlights and dash and when my radar detector turns on it says high volt at the same time all this is happening my airbag light flickers off and on and my heat/ac turns off but it all goes back to normal if i stop and its just idling by the way its a 93 mtx please help its my daily driver
shotime1994
AirHammerAndrew
New York
Hi check the output on your alterantor at the battery terminals. Probably putting out to much voltage. Make shure the car is running when you test it all you need is a volt meter. Andrew
Storm-Chaser
Shit Louis
x2 on the voltage regulator.
Can be bought new for less than $50, and is 4 T-20 torx screws to remove/replace. It takes all of two minutes to change when you have the alternator out.
:burnout:
CademiaX
What's an SHO?
Utah
get rid of the radar detector too, go race on a track if you want to speed.
oneqwicksho
cleveland, ohio
X3 on the voltage regulator and double chech the wire going to the battery my 91 did the same thing and the wire that goes to the positive terminal was arking and causing the problem
letmeshou
maryland
i dont speed except like 5 or 10 over when im on the highway i just have the radar decector from when i used to have my formula firebird and i payed 300 bucks for it back then so why not keep it up there and anyways thats not my main concern right now my car is
letmeshou
maryland
ok well i went to drive it this morning i drove it about 10 miles got on it alittle bit and nothing its like it never happened could it still be the alternator or the regulator?
Storm-Chaser
Shit Louis
Yes. Electrical stuff can have intermittent failures. It may also be the brushes, which are screwed-to the back of the voltage regulator. Replacing the voltage regulator replaces the brushes.
letmeshou
maryland
ok i got the new alternator today but i took a look unter the hood and this aint gonna be easy to fix so can anyone give me a website with the steps for installation and removal
Simple to follow 93MTX alt directions.
Remove battery:
-disconnect cables (negative first)
-back off hold down nuts
-swing hold down out of the way
-lift battery out, set aside
Disconnect Alternator:
-Pull out plug
-Remove power lead (usually a 10 or 11 mm socket)
Detatch alternator:
-Remove the (probably 15mm) bolt from the bottom, rear.
-Remove the (probably 13mm) bolt from the upper
-Loosen and remove (if it'll clear the battery tray) the long through bolt at the bottom, front
-Wiggle alternator from vehicle.
It's actually very easy to replace.
Joe_SHO
ND
before you install the new alternator, you should try simply cleaning the battery terminals.
letmeshou
maryland
hey theres a blot in the back of the alt i cant get to and my terminals are as clean as a new cars there not rust or corossion on them they look brand spankin new
