crank cancer or vacuum leak are my guesses. (If it's not the IAC)
[thread hijack]
I just got done with the driver's side suspension. I had to drill through the pinch bolt and the subframe bushing bolt. I ended up using a 2" hole saw to cut an access hole in the rear unibody outboard of where the subframe bushing bolt goes and using a bolt/nut setup to mount it.
My... god... I gotta tell you, that was way more effort than it was worth. Also, close to $400 in parts already, and that's not including the struts/springs themselves. The passenger side's been soaking in PB blaster for two days now, though, so that side should be a lot easier...
Yeah I bet you wish your problems were as simple or small as mine right about now huh? Well I guess it is off to the parts store this weekend but still broke so I don't know how I will pull this one off. Kiss up to the old lady I guess.
Yes when I disconnect that hose it runs fine, but as soon as it goes back on idle bog city! So I guess that should answer my question that it is plugged somewhere or the solenoid is not opening or bad.
