zex kit
Dogitch
Denver CO
I just installed a zex kit on my car. Everything is installed, but which wire do I hook the white wire to? I have it on the middle wire now but wanted to make sure this is correct. Thanks
olympic
Saskatchewan, Canada
That is correct. To test the system without risking your engine, close the bottle valve, arm the system, turn on the ignition(engine off) and slowly push the gas pedal to the floor. You should hear the nitrous solenoid in the NMU click open around 80% throttle.
If it doesn't seem to work right, there are instructions in the manual on how to calibrate the system to your car.
Dogitch
Denver CO
Thanks, just wanted to be sure. I tested it out before I was ready to try it out, and everything was good. This is a super easy set up, and what a punch it gives.
