"you have got to be kidding"
Sexymeatball
MA
So I have just discovered through the use of a nifty little tool called a caliper, that I have a 24/23 (frt/rear) swaybar combo. "You have got to be kidding" as per the comment on shophoenixproject.com. So now that i know why my handling feels "funny" (translated as severe understeer) when throwing hard into a turn. what is the easiest/cheapest way to fix this? I know 20.6/26 seems to be the ideal combo, but money is at a premium for a college student and if it is going to be more than a few hundred to fix it, I'm tempted to just leave it alone.
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
24/26 is not a bad combination with a stock differential. With a Quaife, you probably want a bit smaller front sway bar.
So, in your case, I would just get a 26mm rear sway bar and call it a day for now. The rear bar is much easier to change than the front, and it will make your car handle much better.
- Mike
Shoaz
Studly dood
Scottsdale, AZ
What you have is certainly drivable, it's just not going to be optimum. Leaving it as it is is a good option if you don't have the $$.
If you can get either a 26mm rear or a 20.6mm front (or thereabouts) cheaply, putting either into what you have now will help. i.e., 24/26 or 20.5/23.
