X-Calibrators work for '96-'97 SHO's
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
X-Calibrator Group Buy from FPS in Atlanta
OK, here you go.
For those that want to get in on this, it starts now and ends Fri, April 15th.
The price of the tuners is $470 (plus a little shipping).
4 or more in the group and the price goes to $425.
6 or more and the price goes to $400.
8 or more and the price goes to $370.
I need an e-mail confirmation with credit card information and shipping address to reserve your spot. I'll e-mail you back with a confirmation and your place in line. I will not hit your card until the Group Buy ends, but when it does, the price is as stated above. I'll post to the list about spots available with numbers. If you are concerned about the security of e-mailing CC info, get in touch with me and we'll work out an alternate plan.
Stocking levels vary, but I usually have 10 of these things on the shelf. New stock is only a couple of days away. The tuners will come with 3 tunes set up for 87 octane, 89 octane and 93 octane fuel. All the other tricks are in the programming. When you place the order, I'll need a list of mods and any requests for special programming if required. Special programming is on a case-by-case basis, but I should be able to accommodate most anything can be done at no charge.
These tuners will work on any car, but only one car at a time. Once you program your vehicle, it's VIN locked to that vehicle. It can be unlocked and used on any other vehicle, but it must be returned to be reset and reflashed. In this case, some programming charges may apply.
Once you buy the hardware, it can be changed or altered for a simple programming fee. If you've upgraded the vehicle, we can upgrade the programming in the tuner to match. If these upgrades were purchased from us, these upgrades can be done at no charge. Contact us directly for details.
This Group Buy is for X-Calibrators for any OBD-II Ford, including '05 Mustang, '04-up F-150, '03-up Powerstroke and '05 Ford GT Supercar. Just give me the info I need and I'll do the rest.
Remember, e-mail me at [email protected] with the info and we'll make it happen.
DavidT
TN
I am still under warranty... will I be up the creek if I have a warranty issue AFTER the XCalib. is installed?
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
David...I think you will be fine, but if it does need to go in for warranty work, I would load the stock program back in first...but even then I am sure it will be hard for any adjuster to tell if the ECU has been tampered with. I am still under warranty, too. My reasoning is, God forbid, should something happen, just load the stock program back in, that way there is no evidence any tampering was ever done.
ornery1
pa
im finally on a list for a camfest in may14-15 in pa... yahooooooooo
DavidT
TN
So, is THIS the "OBD-II twEECer"?
What is the purpose for a laptop with this product?
Does installation simply require plugging it into the OBD-II port (under the dash, I assume)? Computer in the engine bay/firewall is untouched?
In a nutshell, what are the major benefits of THIS ove the sct CHIP?
(My knowledge is limited here... I apologize) :slap:
Vroom
Un-Moderator
South Dakota
Hooray!
Let's get our e-mails sent to Doug and get these things shipped out! :salute:
Remember 8+=$370
EDIT: E-mail sent.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
OK, we're well on the way. Got three tuners confirmed.
1) Adam Philips
2) Roman Steichen
3) Mike Testa
You 3 guys are the first.
Remember, I have to have shipping info, billing info, expiration date and CCV number (last 3 digits in the signing stipe on the back) before I can reserve your slot.
If you're nervous about CC info over the internet, please let me know and we'll make arrangements to get the info some other way.
Thanks and if anyone has any questions, please drop me a line.
SHO#7
Cincinnati
Ok, This has been asked but not answered.
How do you install this. Do I need a laptop, or can I just plug into the OBD-2 port. What is the procedure?
Vroom
Un-Moderator
South Dakota
To reflash your car's computer, plug in and select the program to flash. Then it will flash it.
To change your tuning, you'd need to buy the software and cable to hook up to your laptop.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
1) Adam Philips
2) Roman Steichen
3) Mike Testa
Added to the list:
4) Skye Giebink
5) Lisa Brozovich
6) Carl Orner
We're getting there...
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
SHO Dude said:
Added to the list:
1) Carl Orner
2) Adam Phillips
3) Roman Steichen
4) Skye Giebink
5) Lisa Brozovich
6) Carl Orner
Add another:
7) Brian Phillips
Just a couple more.....
99V8SHO
GasOilAndTires
Doug, would it be possible, if once we get 8, since the price will not drop any lower than $370, if you could send them out ASAP?
