X-Calibrators work for '96-'97 SHO's
DavidT
TN
a couple questions...
if the battery is disconnected, does the computer go back to stock settings?
also, how different is the programming in each of the 3 programs (87, 89, 93 octane)?... say I program the 93 octane in... and start running 87, OR vice versa...
ornery1
pa
also
what is the factory rev limiter set at and where are the normal shift points at?
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
You should be fine running 93 with the 87 programming. I would NOT run 87 with the 93 programming. The 93 programming is programmed so that it can run slightly more timing with the higher octane fuel. Running too much timing with too little octane = SHO boom. However, I don't think running 87 with his 93 programming with blow your engine, it just won't be good for anything. Your knock sensors will probably retard the timing anyways.
Osiris
Grill Man
Oklahoma
No....unplugging the battery will not clear the tune because the flasher is essentially making that tune the new program.
Only by unloading the old tune and uploading the original PCM tune will you go back to the stock tune.
spragers
central WI
WOOT! I just made it in by the skin of my teeth.
At least I think I did - just waiting to hear back from Doug for a confirmation :dribble:
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
X-Calibrator Group Buy is complete
That's it, it's over. Thank you all very much for placing the orders and following thru.
Here is the final list of folks and a few details:
Carl Orner - standard 97 3 program tuning
Adam Philips - standard 97 3 program tuning
Roman Steichman - standard 99-Late 3 program tuning
Mike Testa - standard 97 3 program tuning
Skye Giebink - standard 97 3 program tuning except 89 Octane fuel is 10% Ethanol and high program is 91 octane
Lisa Brozovich - standard 96 3 program tuning
Brian Phillips - standard 97 3 program tuning
Lucien Frederick - standard 96 3 program tuning but set for 4000' elevation
Johnn Lester - standard 97 3 program tuning but no IMRC (open all the time)
Ian Macoomb - standard 97 3 program tuning
Chrisa Crawford - standard 97 3 program tuning but no SAI
Aaron Powers - standard 97 3 program tuning
Jim - 97 programming with 93 octane, 95 octane and 75hp NOS
Shane Torsell - standard 99-late 3 programming tuning
Benjamen Sprague - standard 98 3 program tuning
David Arseault - standard 97 3 program tuning
Ryan Moss - standard 96 3 program tuning
Joseph fondessy 87oct + IMRC@3200, 89oct + IMRC@3400 & 93oct + IMRC@3400, no downstream O2's
Barry English - standard 98 3 program tuning
That's 19 total.
Thank you all so much for the orders. The tuners will be here tomorrow, Wednesday 04/20/05 and I'll be a programming Mad-man on Thursday. They should all be ready to go out Fri 04/22/05. I'll post again when they go out.
If your name is on the list, but something is not right, please let me know. If your name is supposed to be on the list and isn't, please let me know.
Thanks agian.
__________________
3.2L headgaskets in stock!
Doug Lewis
[email protected]
Ford Performance Specialists Inc.
Atlanta Georgia
770-949-7191
http://www.fordspecialists.com
2001 F-250 Powerstroke-
Garrett turbo - 700ft-lbs
1996 TR SHO-
Long tubes - bottle fed - low and fast
1989 CR SHO-
Shaftdrive supercharger - 400hp
Porkchop
The Black Sheep
Virginia
Roman - you better get your butt up here so I can ride in your car once you tune it up
99V8SHO
GasOilAndTires
Go to the convention...that is probably the earliest you will be able to see me. Unless I work up some energy after this semester to go on a road trip to New England.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
X-Calibrators are in the mail
Mailed them out yesterday.
You guys and girls should be getting them Fri or Mon.
They all went out Priority Mail.
Read the directions and follow my tip on the invoice. Pull the fuel pump relay before you program the car.
Enjoy.
It was a pleasure dealing with you all. Went very smooth. No headaches.
Thanks again to all.
__________________
Doug Lewis
[email protected]
Atlanta Georgia
770-949-7191
1996 TR SHO-
1989 CR SHO-
CT97White
West Hartford, CT
My cable broke. I saw a few posts here & on V8sho.com where people had wired the secondaries open so I decided to try it. It doesn't seem to make much difference one way or the other. It does seem to make it idle a bit rich, but other than that it just saved me the expense of a new IMRC controller.
DavidT
TN
woohoo!
The mail lady kindly delivered it 5 minutes ago :)
DavidT
TN
problem...
the stock setting on the XCal is AWL1. My 97 is AWL2. Are they the same... is it safe to use? :corn:
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Regardless of what the car came with or has been programmed to, the AWL1 program still works in all '96 and '97 SHO's. There is more access in the tuning files for that code than any other for those years. '98 has it's own code, then '99 has 2 different codes depending on the tranny (O/D cancel or not).
Enjoy.
DavidT
TN
Enjoy.
OK :biggrin:
I have one year left on the warranty. Will the AWL1 programming be a potential problem?
Vroom
Un-Moderator
South Dakota
Got mine today as well, but couldn't try until after work.
Observations:
Yep, neutral rev limiter is bumped up. A quick blip to 5k and I was satisfied.
Parking rev limiter is DEFINITELY bumped up. Did a quick rev to 4500 at the gas station (after the test drive :evilgrin: ) and watched all the heads turn. :hail:
Shifting is nice and firm now. At WOT, the car lunges forward as it redlines the 1-2, AND pulls ******* the 2-3.
I wanted to test the speed limiter, as it was removed with the SCT, but could only get to 135 before I started an uphill climb. Dang does it feel good to be triple digits downhill, teeth clamped and ears popped!
Can't wait to do more driving with the '97 now! I'm quite impressed so far.
Thanks, Doug!
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
DavidT said:
OK :biggrin:
The SCT tuner forces what ever program in that I've installed in the tuner. The fact that you've got a JJK2, JJK3, AWL1, AWL2, KMM0, YIY0, YIY1 or any other program for a '96-'97 SHO is immaterial and has no bearing on the fact that my tuning files will be installed in your car.
As far as warranty, there is no way that an adjuster could see what tuning files have been installed. If there is a warranty issue, you can simply return the factory tuning from the tuner and there is no programming trail to follow.
Just make sure the fuel system is disabled before installing the tuning. When the tuning begins, the cooling fans and the fuel pump run constantly as the programming is being downloaded and uploaded. Disabling the fuel pump prevents any fuel related mishap.
__________________
Doug Lewis
[email protected]
Atlanta Georgia
770-949-7191
1996 TR SHO-
1989 CR SHO-
ornery1
pa
awesome!!! my car kicks *** now when it shifts. pulls alot harder all the way threw the gears.
