I recently got a 93 3.0 MTX- 90k w/ 60k maintenance complete- Original (for now) Runs GREAT! Bought just before winter and just started driving again. I've read all the posts on hard shift problems and completed the following- used clutch pedal adjuster- got it to click. Changed trans fluid (got out 3 quarts). (BTW- had shifter and mechanism checked when I bought it at a Trans. shop and was told Manual trans fluid never had to be changed cause it doesn't heat up like auto!). Problem is worst going into first or reverse. It will shift smooth as butter one time, and be almost impossible to get into first or reverse the next (or somewhere in between). When it is hard to get into gear it will grind, but otherwise there seems to be plenty of clutch. Doesn't seem to relate to hot or cold weather or whether it's warmed up or cold, and nearly every time it's different. I'm not a true mechanic, but handy, and currently have no garage (Mother in law there instead). Is there any other external linkage or bushing that might be worn in the shifter etc. Probably just hopeful thinking, my best guess is worn TOB thats in a different position every shift. Should I start preparing for Clutch, TOB etc.? This is a great forum, if that's the case i'll start reading up.
