I have a 99 that I just got the engine purring like a kitten now I'm trying to diagnose the transmission. Here's the jist, when I first start it up it will not shift into OD, ever. Once It has been driven about 10-15mins it "might" shift into OD, but will "slide" back to 3rd if you apply any throttle. Then if you get the entire car up to operating temp (about 20-25 mins) it will almost never shift into OD (and sometimes shifts a little hard from 1st to 2nd). Then the OD light will start flashing at that point. I've just flushed the trans and changed filter (yes it was black, but not full of "pieces", magnet was a little "hairy"). So, I'm thinking either the OD servo is not working, OD accumulator circuit is faulty or..... The OD band is burnt and/or gone......
Thoughts/comments?????????
