sho_can
Hey all,
okay this morning got in my car and it started up fine, but then like two hours later tryed to start it and it wouldn't start, so checked codes and came up with *556 Fuel pump primary circuit failure*-->*543 Fuel pump secondary circuit failure*--> & a *122 TP sensor circuit below minimum voltage*... the first two are because the car died right? and would the TP sensor cause it not to start at all? also is there any codes sent if the DIS module on the side of the intake goes bad? just wondering.
Thanks all, I really don't know what is going on, it runs great, except some times on start up it wouldn't idle right.
