Wiring to multifunction switch
SHOGIRL1994
ExFSHOCmanager
Jacksonville, FL
I have the classic symptoms of a MFS gone bad. Basically everything works but the actual headlights and the only way I could drive at night is by holding the stalk back so the brights stay on. I tried swapping out the MFS with one out of my other 89 parts car and still have the same problem. A few nights ago it started smoking from that area while I was driving and I lost my headlights immediately, so I know the problem is right there. In looking at the connectors, the long flat one is a bit melted in the center. I've tested all the contacts on the connector with a test light and I'm not getting power at the center of it, which are two red wires with a black stripe. So I suppose there is a short in that wire somewhere.
I have downloaded the '89 wiring diagram and none of it makes sense to me whatsoever. How can I trace where those wires go? Or am I better off just running an auxilary switch for my headlights and saying to **** with it?
Racer X
SHO Pilot, Retired
Connecticut
You're going to have to replace that connector with a good one. The good news is that you don't have to cut wires if you don't want to; you can just remove the terminals and swap them one by one onto the new terminal. The problem isn't so much the connector, but the MFS internally has a fault that ends up overheating those terminals and melting the plastic connector.
FWIW, the same thing happened to my '89 SLO some years ago, and this is what I had to do to fix the problem.
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
My 89 SHO did the same thing as well, smelt burning plastic, and lost my headlights.
I upgraded to the 90-95 switch and wiring, it was a pain to wire in, but I made it work, then I did the 90 dash swap inc wiring harness
