Wiring Diagram for Distribution Box 95 ATX
digsj7
Digsj7
Columbus ne
Anyone have a wiring diagram for the distribution box under the hood for a 95 ATX? I tried to search for one, but came up empty. I keep blowing my 10A ASSY FEED mini fuse and need to start tracing wires. Any help would be appreciated!!!
digsj7
Digsj7
Columbus ne
What is the reason why my car starts up, revs to 1000rpm and then dies right away and every time that fuse is blowing out?
The ASSY FEED fuse will not cause a crank but no fire problem.
Perhaps you have the legend wrong and you're actually blowing the IGN COIL fuse which is next to the ASSY FEED fuse. If so, disconnect the coolant level sensor on the coolant recovery tank and try again.
digsj7
Digsj7
Columbus ne
I must of, cause thats whats happening. I disconnected the coolant level sensor already and tried finding a short but so far I cant find one. It was also wierd that i got the car to finally start up and it wouldnt shift into gear. I disconnected the linkage for the safety switch and it is now drivable again.
It is still acting funny though. Everything seems ok except my speakers dont work (radio is on, just no sound) and it is cutting out like it's missing. It will run like junk with no power and when I nail the throttle it comes out of it and the powers back. Do I have a whole new problem? I have to assume that it is a excisting problem from the fuse deal.
bmytych
