wiring colors for alarm
khanartist
oldtimer....
Windsor, ON, CA
1992-93 Ford Taurus Security Information
Constant 12V+
-Yellow
-Ignition Switch Harness
Starter
-White/Pink
Ignition
-Red/Light Green
Accessory
-Gray/Yellow
-Ignition Switch Harness (Blue/Green for Heat/AC)
Tach
-Tan/Yellow
-Coil
Neutral Safety Wire
-Not Grounding
-OEM Switch opens Starter Circuit
Brake Switch
-Red/Green
-in 6-Pin Connector behind Dimmer or at Switch
Trunk Release
-Purple/Yellow (+)
-Keyless Module behind Passenger's Seat
Parking Lights
-Brown (+)
-Light Switch
Head Lamp
-Red/Yellow (+)
-Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger
-Gray (+)
-Dimmer,
-also Light/Light Blue in Kick Panel
Door Lock
-Pink/Yellow
-Driver's Kick Panel Reverse Polarity
Door Unlock-Pink/Light Green
-W/Keyless Negative Trigger
Horn Wire
-Yellow/Light Green (-)
-Steering Column
Windows Up
-LF=Yellow, RF=Yellow/Light Blue
Windows Down
-LF=White/Black, RF=Gray/Orange
