Windows wont work
gbizzle27
Bradford, Pa
Well my windows do not work. They have been acting up recently, however today i put them down and low and behold now its taken a complete dump and wont go up. To add to that it downpoured after i got home and everything is soaked. The rear windows haven't worked for a long time now to add to that. I know its not the master switch because i replaced it with another. Also, the unlock button doesn't work. So basically everything electronic in the door is a no go. Tell me whats wrong, i don't want to deal with the thing anymore.
spazmoid
RI
Just yesterday I had this same problem. My back right window would not go up. After taking the motor apart and deciding it was fine I started testing the wires and found that there was no power coming from the drivers door in the up position. I took the switches apart on the drivers door, a few screws and some clips. Get down to the last layer, the copper panel where the actual contacts are. I sprayed this down with contact cleaner spray and made sure it was dry by using an airhose to evaporate everything. This worked for me. Seeing yours got wet I'm gonna guess they're corroded so hopefully this helps.
