windows wont work
WhiteSHO625
il
hi i have a 91 SHO and i have been haveing problems with my windows not working and my moonroof at the the same time i have checked the fuse and its fine i have takein apart the door and checked the wires and they seem fine can someone help me
More than 1 window? Most likely the master switch on the door. Power is routed through that to the rest of the windows. Not sure if the moonroof malfunction is connected or a seperate issue.
jlunde15
nonstop project
Texas
The moonroof not working might be the relay behind the glove box. If it's factory, it's a little silver cube with a BMW logo on it. Tap it lightly a couple of times while attempting to move the sunroof, that may rule out one of your issues.
Sounds like you need a trip to your local adult candy store...i mean, pick 'n' pull. check it out, find an old taurus, grab a window switch, try it in your car. If it works, problem solved...if not, you're only out about $10.
WhiteSHO625
il
yes more then one window all the windows eather work or dont work at the same time and the moonroof dont work and no its not the master switch i **** the one out of my 90 SHO and they still did not work
jlunde15
nonstop project
Texas
Do you hear any noise when trying to operate the moonroof: any clicking, grinding, etc.?
...or...sell it and buy a motorcycle. No windows to worry about.
jw89sho
TN
x2 on the relay behind the glove box. It's the accessory relay for the windows/moonroof and is triggered by the white/(some color) striped wire from the ign switch.
