It's not really that bad. Here's how to get the front ones off:
1) Remove the inside door panel.
2) Remove the 2 corner pieces at the ends of the inside belt window molding (they are glued on)
3) Remove the inside belt window (it just pulls off)
4) Remove the outside belt molding. There is a nut on the door handle end of the trim, remove it and it just pulls off.
5) Locate and remove the forward run channel bracket bolt, it a few inches below the speaker.
6) Remove the speaker (you don't have to remove the sepeaker but is easier if you do
7) Lower the window and start pulling the run channel down, once you have the rear of the channel down enough you can pull it forwant and piviot the entire piece out of the door.
8) Drill out the rivits that hold the chrome trim in place and remove the trim.
Heres how to do the back:
4) Remove the outside belt molding. There are nuts on both ends, remove them and it just pulls off.
5) Lower the window and start pulling the run channel down, once you have the rear of the channel down enough you can pull it forwant and piviot the entire piece out of the door.
6) Drill out the rivits that hold the chrome trim in place and remove the trim.
