Window problems
EMB2580
Mike is a L O S E R
Zion, Il
Has anyone had this problem with their power windows? I can hear the motor when I press the button but windows will not budge, even when I pull or push on the glass while pressing the button. They are still on track, but it's like the gears are stripped or a bad regulator. It's the driver's window (of course, LOL) and both rear windows. the left rear window is down about half an inch and it's cold up here! LOL The front passenger one works fine (after a little silcone spray, was super slow) Also, I don't really care about this but both rear switches on the back doors are dead, just want to get the driver's window working, any ideas for this one guys?
etc1006
Baltimore, Md.
Definetly sounds like the motors. Only where you can hear them though. But most time I've been able to "help" them go up or down if thats the case. If the buttons at the back arent doing anything, first make sure the lock switch for the windows is off. If ok then its probably your main switch on your door. I can't make the pass front go up all the time from my door... And sometimes it goes down reeeaaallll ssssslllloooowwww....
EMB2580
Mike is a L O S E R
Zion, Il
I made the mistake of "helping" the driver's window down, lol...went through **** getting it back up, but it's all the way up now. Took the 3 screw out that hold the motor in place but it won't budge! LR swicth does nothing, R.R. works for up, not for down. I read somewhere they could have dirty contacts.
ohfosho
ontario SHOwner
ontario, canada
my drivers window is slow...but it just started with the winter cold and snow that came in...is there a way to **** them up?
EMB2580
Mike is a L O S E R
Zion, Il
I used some silicone spray on mine. ASpray the tracks with it. WD-40 will work too, but is oil based and tends to attract dirt.
