Will this work for our manual trannys?
Warren
New York, N.Y.
http://www.collectorcarsforsale.com...-Bearing-Kit-85-87-For-Sale_170548892098.html
Is this mtx5 the same thats in our SHO?
gmorrell
Never been a noob...
Colorado Springs, CO
I've never heard of an MTX5 from that vintage, there was an M5TXA for some sub-2-liter applications back then, and it's often incorrectly referred to as an MTX5.
The SHO MTX-IV was derived from the ****** MTX-III (three), which was a also a 5-speed. With the exception of a few of the bearings, most of those parts should work in an MTX-IV.
Phoenix
SHOHOLIC
QC , Canada
And Tempos
As far as bearings , most of them are available in the local bearing shop , except one or 2 , I had a bad one in mine when I rebuilt a scrapped one , and theres NO WAY IN **** you can have these in new. And I tried , Even called the company that makes them (SOYO).
moobypets
mooby
quebec
humm im sure i coudl find a replacement
there some nice shop here in montreal i just have to tell that the bearing is not for a car lol if i say yes they will not sell me i just need to have the actual bearing in hand
but on mine im hearing some sound on 1 when cold when it get hot it almost gone
and what does the sound off a quaife sound like?
gmorrell
That are two bearings in the MTX-IV that appear to have standard Bearing Interchange Numbers, but the ID of the inner race is non-standard, so when you get the standard bearing, it won't work in the application. AFAICT, these were made for Mazda/Ford by KOYO.
If my old-ass notes are correct, the bearings are:
1. Input shaft (case end), the outer race is a standard LM48510-N, the cone-roller assembly is Koyo/Hi-Cap ST3265-N, this was Ford PN E9DZ-7025-A.
2. 1 to 4 output shaft, (bell housing or pinion gear end), the outer race is again an LM48510-N, but the cone/roller assembly is Koyo/Hi-Cap ST2765-1-N, this one was Ford PN E9DZ-7025-B.
Everything else in the MTX-IV is standard stuff.
(Outer race/cone-roller assembly)
Input shaft, clutch end: Timken LM67010/LM67049A.
Output shaft, case end: Timken LM67010/JLM67042, otherwise known as Timken Set 30.
5th gear shaft, both ends: Timken LM12711/LM12749, otherwise known as Timken Set 16.
