Will a GenI speed sensor work in a GenII?
Mikey
Dallas, Pa
I did a motor and tranny swap and left the 89's vss in the tranny, the plugs matched up but i have code 452. If I get outta work early this week i am just gonna switch em up and see if this fixes the problem. If not i'll have to get it on sunday. Just wanted to see if anyone knew off the top of their head. Thank you SHO much
lol
You most likely have either an open VSS or an open circuit between the VCC and the PCM (Pins 3 and 6). The VSS coil should measure around 1100-1300 ohms.
Mikey
Dallas, Pa
:thumb:Thank you my kind Sir. I'm gonna pull the ohms meter out and check it out. Thanks for the direction i never had any problem with speed sensors in any vehicle before. Thanks for the pin numbers too, great.
This Forum is the BEST hail
