Why would the PRO-M 80mm make soot?
NEILL93SHO
Yuma Az
I have gone back and forth with the 55mm and 80mm pro-m. The pro-m does give me stronger pull through the gears (butt dino?) but within a day or so i start to see some soot around the tail pipes. The stock brings me back to clean and wishing the 80mm worked better. Any Ideas?
Mr Anonymous
Tire Wall
Only way to tell for sure is to get your car on a dyno with an a/f reading to see the difference between the two. Are you getting a CEL with rich O2 codes when running the Pro-M?
