mlatten
Mons-taurus
I think I may have read every post on this site! So, I was wondering if you guys could help me on a few things. Here goes nothing.
What is the best way to clean the MAF? I've wiped it out a few times, but have no idea what I should use on the sensor itself, if anything.
Is the steering on a 95 MTX supposed to be a little stiffer than on a 95 ATX, or is my VAPS just screwy?
You know that black plastic piece that holds the headlights and top of the front bumper cover? Is it the same part in a regular Taurus/Sable? Hoping to save a few bucks at the bone yard.
Does anyone have dimensions for the engine bay? I know mine was hit before I rebuilt it, but no matter where I adjust the hood it won't close right. Anything appreciated.
Are the two bolt holes on the front of the transmission (side facing the headlights) just generic for that housing, or am I missing something? The holes look almost new, so I suspect something was removed.
Lastly, and most importantly, I believe I have a rear mount issue. Before I go and spend the $180, I was hoping to get your guys insight. As farfetched as it sounds I think - really - that both mounts are actually broken - here's why. If I bang into reverse, the whole engine bucks like crazy, almost hitting the closed hood. But it jumps forward and backward, which makes me think that something else is causing it - if it was just the mount, it would stay in the direction of the pressure being applied, right? But here is what I think is happening. With both mounts failed, I think the engine is moving SO much, that it is pulling away from the clutch pedal enough to disengage the fork, relieving the pressure, dropping back an inch or two, reapplying the clutch, pushing up, and repeating. Does that sound possible, or am I doomed to waste $250 on reinforced mounts?
I really thank everyone who says anything at all. These are all just things that I've let build up that I want to resolve.
Cheers, Matt
Cheers, Matt
