I am trying to rebuild mine but cant get the the main part out. I was able to get the front part of the case off but now I am stuck. :/
The "main part" as in the rotor?
If so, chances are the brushes won't let the slip rings get past, which means you'll have to force it and break the brushes in the process (which is no biggie since new brushes are a standard part of a rebuild).
If you have a small sharp pick or probe you may be able to use it to retract the brushes sufficiently by using it in the hole that is normally used to hold the brushes retracted until the alt is assembled.
