whining noise
LeeSHO
Tripls S
New York
i hear this whinning noise in the engine, i thought it was the ps pump thats bad but i don't hear any noises when steering. its gets louder as i rev the engine
LeeSHO
Tripls S
New York
i don't know wat a super charger sounds like but maybe, how much is it to change and where is it located?
sho_me92
it`s SHO time
utah
i dont think it would be much to replace ..it is the pully the looseins the belt and tightins it
naval-avi8or
Chesapeake, VA
Could also be the alt bearing.
ycode90
Out in front!
My idler pully has been making noise for over a year. It does sound like a supercharger. Its easy to replace im just very lazy.
Bolt20
Mesquite NV.
Any ideas wherre to get ideler pullys for a 93 SHO?? This one here totally discingrated..and tha parts arnt made anymore from what I understand
91PDXmocha
Portland , Oregon
Take off the belts , see if it still makes noise . If it goes away then it's a idler bearing . If it continues then its timing belt tensioner . Is this a atx or mtx ?
TopGunnYFZ
Livonia, MI
Change it now before it flies off and leaves you with shards of belt twisted around everything, and need a tow because your car is overheating. Ask me how i know this happens LOL
oneqwicksho
cleveland, ohio
is it an atx or mtx? if mtx could also be a worn timing belt tensioner. i would recomend for and mtx take one belt off start the car did the noise go away? if yes then idler bearing bad or alt bearing. if no pull the next belt, did the noise go away? if yes then idler bearing or powerstearing. if not then i would say timing belt tensioner im having that problem right now
