You can make the rears wear faster if you activate the AWD and traction control more often, as every proper SHO owner should![]()
I do! Which is why I'm asking. I get the theory (which is why I said I assume the fronts), but was hoping for a real world answer.
Maybe this is a better way.... If I drive the car hard and never rotate the tires, will they wear evenly with the AWD, or will the fronts or rears were out first.
You got a real world answer. The power is biased to the front, the braking is biased to the front, the weight is biased to the front. You ever owned a fwd car before? Yeah yeah I know it says awd. it's power is biased to the front.I do! Which is why I'm asking. I get the theory (which is why I said I assume the fronts), but was hoping for a real world answer.
I gave you the correct answer. If you don't rotate the tires the front will wear out faster.
That is everyone's experience who have had both driveline platforms. Sometimes you just don't know the age/ownership profile of the person posting, so it's hard to assume previous experience. You have had both rwd/fwd platforms and know how they wear. Curiosity is good but in this case you know enough to proceed accordingly. Trust your experience. You got thisYes, I've had FWD and know they eat front tires. And my RWDs go through the rears first. Just wanted someone's experiance on these cars.
If the case is that it is not in AWD that often is why it does not need perfect sizes then wouldn't that be the same here? Everyone keeps saying the SHO is FWD with short spurts of AWD. My NX is tuned, water/meth, full intake, full downpipe exhaust and I never spin the front wheels. The SHO spun the fronts the first time I stepped on it. So it would seem the NX is more AWD than the SHO.
How is out AWD engaged? Is it a viscous clutch system? Is it all electronic off wheel speeds and slip?
Love cutaways, that was an amazing explanation. Thank you
So "The Book" notes our car is primarily FWD, but under heavy acell, aggressive handling, or wheel slip is detected torque is provided to the rear wheels via the ATC clutch.
The PTU is a gear to gear trasfercase that is splined to the front differential.
