Which Motor Mount?
HotBoxSHO
Portland, Maine
I'm home for Christmas, and it's time for some repairs on the SHO. First off is my broken front motor mount. I was pretty sure that the SHO uses a solid mount. However the guys down at Carquest said that I had the option between a solid mount and a liquid mount. What do you guys think? As far as I knew, my options are to either replace with an OEM part.(which I plan to do because its only $60 with my discount.) Or buy a reinforced one from sho nut. Are these guys full of crap? Help me out guys, I need to buy it today. Thanks
'93 SHO ATX. Coneless and boxless, 15% tint.
RJ-92
Crappy NYS
He's right there were liquid mounts but I believe they were only for the automatics. So I'm pretty sure you would need them. I would go with the reinforced if they make them for the ATX.
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
dynomax cat-back w/1 superturbo & 1 ultra-flo muffler,
street/strip clutch,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs, 26mm RSB
In storage for the winter
HotBoxSHO
Portland, Maine
Awesome, thanks alot. Liquid mount it is then. It's only about $15 more then the solid mount.
S
slosho
Guest
Since when do they have reinforced ATX mounts?
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" lines
Lighting mods
Convinience mods
More to come.
SHODUDE
Valdosta, GA
Get the liquid mount. Its the only correct listing.
The "solid" mount is for the other Tauri I believe.
P.S. Nobody makes a reinforced mount for the ATX.
mailto:[email protected][email protected]</A>
1990 SHO FOR Parts
1991 SHO SOLD [email protected]
Need SHO parts?
Click here&gt; http://cgi6.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewListedItems&[email protected]
DemonNeno
SHOCAGO Freak
Skokie, IL
SHODUDE
Not true... SHO SHOps, according to their webpage, now offer reinforced ATX motor mounts. Also, I'd advise you don't get any kind of mount and slap it in your SHO! That's a tsk tsk, in my opinion. Get something well worth the money as your traction, ride feel and expected life span of the mounts rely on it.... The mounts are listed @ shoshop.com under '89-'95 SHO > Drivetrain > Engine Support...
Good luck with your pick!
Neno & The '91 Dark SHO
SHOCAGO Enthusiasts Club - http://www.shocago.com
137K Mi., Black on Black/Mocha Interior, '94 Mark VIII Rims, 225/50VR16 Comp TA VR, Rod Shifter Converted (Broken stabilizer bolt, still sitting in my trans housing!), SHO Nut Reinforced Motor mounts, Coneless, 3.2L larger crossover tube for intake installed (sure did make the intake LOUDER!), Delrin SFBs, Semi-loud exhaust system...
Ready To Install: Subframe Connectors and Intrax springs instead of Eibachs?
Coming Soon?Konis/Poly setup
