which BP/MAP sensor to buy?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
I'm using a GP Sorensen 77911501 in my car. $47.99 from Advance/Checker.
Just out of curiousity, what symptoms are you trying to cure by replacing it? It only affects startup and WOT, to the best of my knowledge.
centaurus3200
oakland, ca usa
thanks,
car was stumbling off idle real badly. much like a bad tps, but it wasn't the tps. eec finally threw the map sensor code. tried a friend's. totally fixed.
previously measured the tps, tps connector, tried a different dis, coil pack, new plugs, pulled the cam sensor out of the circuit, stock maf. it is definitely the bp/map sensor.
see ya,
Robby
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Cool. Maybe I'll go exchange mine and see if it helps anything. Mine's had a cold-start hesitation and stumble, and a low rpm/high load hesitation and bog for a while.
