Where to purchase SFB's and MM's?
Nebuchadnezzar
Michigan
Greetings,
I'm going to replace all three motor mounts and all four subframe bushings.
HELP! I need to find out where I can spend the least amount of money! :)
Which motor mounts should I buy? Regular mounts? Reinforced mounts? (BTW, I drive my SHO very *hard*)
Which SFB's to buy? The stock replacements? The police bushings? The billet aluminum ones?
I'm in the dark as to which ones I should purchase, and then, where to find them for as little as possible.
(I'll spend the extra money for the better parts, if need be).
Thanks, all!
Nebuchadnezzar
Michigan
Which SFB's should I pick up? Choices I've found: OEM, Police OEM, Delrin, or Aluminum. Are there any drawbacks to the Aluminum or Delrin? Are the Police OEM any good?
Please advise.
underdog1924
Haverhill, MA
Obviously the OEM ones are stock. Police I believe are a little stiffer, blue colored, and a little thicker. Delrin are even stiffer, but I have read here that they tend to deform easily. Alunimun are the stiffest (obviously). I believe they give the hardest ride and at higher speeds tend to drone. Hope this helps and if I am wrong with any of this feel free to correct me.
