Where to buy radiator cooling fan motor ?
racenutz
Cedar Rapids, Ia U.S.A.
I've been trying for the last week to find a replacement motor but haven't been able to find one yet. I found out the hard way that the replacement fan assemble that AutoZone sells isn't for a SHO.
Is the motor for a 3.8L Taurus the same?
The reason the motor stopped working is the brushes are worn out. Would it be easiest to have it rebuilt?
DHMag
Free At Last
InCahoots, Texas
racenutz:
mine quit working as well, and i couldnt find one to save my life, nor did could i justify buying one for 80 dollas that wasnt even the right part. so i replaced the brushes. they are the wrong grade of carbon and i had to use a dremel to file em down to get em to fit. now, when my fan comes on, all lights dim and Volt gauge needs drops to 10V for 1 second, then jumps back up to 13.
racenutz
Looks like I'll be able to buy one from a parted out car. Do the MTX & ATX cars use the same fan?
Slo-Sho:
Got mine at AZ w/ a lifetime warranty. I also have the dual fan setup.
The fan assembly that AutoZone listed in their catalog was for a standard 3.0L Taurus, not a SHO. Is the dual fan setup an aftermarket one?
LaTechSHO
Louisiana
no.... assuming i'm remembering correctly
ATX cars use a dual fan setup...
MTX cars use a single fan setup....
and the proper fan motor should be available to you via a local parts store
what is the part number of the one that you got that didn't work?
Louis
racenutz
LaTechSHO:
If this works it was the "RADIATOR FAN ASSEMBLY" on the bottom of the page. click
AutoZone doesn't list a replacement motor for the SHO, neither does O’reily Auto Parts (only had listings for universal fans) or NAPA (only had a listing for 3.8L motor)
racenutz
Well, that link didn't work
Here's the info for the fan from AutoZone
SIEMENS_NEW RADIATOR FAN ASSEMBLY for a 1992 FORD TAURUS
Unit Price: $129.99
Core Value*: $0.00
Part No.: FA70025
Weight: 7.76 lbs.
Rob94
Northbridge MA
FYI, the dealer doesn't have a SHO specific listing for an electric cooling fan. Not everything on this car is specific to SHO. The engine is unique, the rest is a POS Taurus. Dealer part number for the new fan for is F4DZ 8C607 B. List price is $250.
racenutz
Rob94:
Part # on my (bad) motor is F0DU-8K621-CA
Yeah, I know that other than the engine a SHO is just like a regular Taurus, however, unless the SHO shares the same motor as a 3.8L the cooling fan motor IS a SHO specific part.
Bizzy
Rob94:
They're all a "POS Taurus" if you want to think about it that way ..... just some of the parts are unique to an SHO. jpshakeh
I thank my lucky stars that some of the parts are the same because the costs of the replacement parts are less because of it.
<small>[ August 07, 2003, 12:31 PM: Message edited by: Bizzy ]</small>
