bmcreider
Got Secondaries?
Ok I would love to get my alarm working again as well as my keyless entry....Now I have a 1991 with the keyless entry on the door, a siren under the hood, and every time I disconnect the battery the lights and siren go off...
I used to have the keyless entry remote for the car, until it broke off my keys and is now history. I think I found the brain in between the radio and the steering column under the dash, it has about 5 or 6 different kind of wires going into it. I know that the keyless remote had an ARM (red) and a DISARM (green) button on it, and if I ever did arm it, it'd disable the starter of course, and it also had a shock sensor, and if you pulled up on the door handle or messed with the keyless entry, or opened a door with the key, it'd go off....
Now-a-days, I just have the valet switch taken out so I can start the car without having to press it.
But, anyways, I looked for the little gray connector with those pins in it that you are supposed to short, that come out of the keyless entry module, and I can't find it. I looked all over the trunk, all around the fuel cut off switch, behind the seat, under the seat, behind the glovebox, etc....anyone have a picture of it or any other ideas where it could be? It'd be nice.
