where does the water like to hide?
yzstud
< my kawi
Minnesnowta
So i went through a car wash on saturday with my 95 3.2 mtx and after I pulled out it was spitting and sputtering pretty bad. So when I got home i blew out all the plug wires and on the coil but with to no success, the car is still missing. It ran super great before the wash, but the second I was driving out it started sputtering. Any Ideas? :shrug:
yzstud
< my kawi
Minnesnowta
oh yeah i also forgot to mention, now when i push my clutch pedal in, the idle goes and stays up at 2700 rpm :oogle:
hawkeye18
Sorta cares
Norfolk, VA
probably got the IAC all messed up. Unplug it and blow it out. In fact, unplug every connector you can see and blow it out. TPS, MAF, ACT, IAC, etc etc etc.
JoesSHO
Reality
How did all of that water manage to get under the hood in an automatic car wash?
jthod
Mr. Goodwrench
Lincoln, Nebraska
Most of the 'good' (expensive) ones have a few jets of water that you drive over as you enter it.
JoesSHO
Reality
Yeah, but I've never seen anything get that drenched from an underbody spray!
yzstud
< my kawi
Minnesnowta
my local one is the best one i have ever seen. It is also the only one that i know of that has underbody jets
it does one **** of a job, just don't bring the sho in there
I can bring in my gtp and the wifes bonneville, but my sho is a no go for this wash
Oh and by the way, all problems were fixed. I pulled apart almost every connector and blew them out and the car runs good now.
Oh, and the high idle was caused by my cruise control cable binding against the tb, therefore not allowing the spring to return to the proper position
