Wheels
Phoenix
SHOHOLIC
QC , Canada
I bought one off ebay , used it and re-sold it - I lost about 40$ which is ok for one use.
AREA 91
PA SHO SHOP
Area 91
I was wondering if anybody else stuffed some 18 wheels under their SHO. I found a set of 18x8(5x108) with 235/40's on them for $400 and they actually look pretty good. They going to fit? Rims
I have a set of 19X8 rims and I had to trim the wheel well on my 91.
I ysed some masking tape and a cut off wheel.
DDakRT
Mississauga, Ont, Canada
As some others have said, the heat gun is used to warm up the paint so it won't crack when you're rolling the sheet metal.
No need to over heat the paint, just hot enough that you still can, but won't be comfortable touching it.
Otherwise just be patient, set aside at least 2 hours for the first fender if it's your first time using the roller. The other fender will likely take you 1/2 the time as the first, but don't rush or you'll likely crack the paint.
shotyme92
WOT :)
Forest City, IA
Finally got an email back from the guy and the offset is 45mm and the backspacing is 6.29inches.... not goin to work are they?
DDakRT
Sweet. I'll probably pick them up next week then.
Can you ask to test fit one on the rear first? 45mm offset is definitely not ideal for our cars and unless he would let you return them, you could potentially end up with 4 very heavy, very large, and very expensive paper weight.
shotyme92
WOT :)
Forest City, IA
Yea, I was thinking I was going to bring a jack and impact gun with me and test one out before I actually purchased them.
