wheels adapters
SHODWN93
OHIO
hi everyone, has anyone ever used those wheel adapters to, like for example change the bolt pattern from 5x4.25 - 5x4.50 . i would think by looking at them that at one problem would be that it would make the rims stick out wouldnt it?
Phoenix
SHOHOLIC
QC , Canada
Yup , If you want to counter this you need to play with the offset - and the wheels with these kind of offsets are even rarer.
92sho16
b00sted
Liverpool, NY
I thought the 05+ mustangs had a high offset like in the 50mm range, if so i would look at those
Edit: tirerack shows quite a few wheels for 05+ mustang 40-45mm offset , mistu eclipse same bolt pattern saw a couple of wheels with 48mm offset. Not sure if that is really enough but you should contact superchargeshoguy i think is his forum tag hes from florida im pretty sure he was putting a group buy together for spacers awhile back.
Phoenix
SHOHOLIC
QC , Canada
well 60mm offset should be ideal since we are using around 40mm.
just so you know 25mm = one inch. So I hope your adaptors are super thin.
