wheel/ suspension components instead
benson
Taiwan
Sorry to ask stupid question here,
does generation III SHO use same wheel/ suspension component with narmal Taurus 3.0,
I mean besides shockers different, can I use those components on my baby?
thanks in advance!
Ben
PS.I am outside of USA, hard to find the real SHO component.
Porkchop
The Black Sheep
Virginia
What parts are you specifically looking for/inquiring about??
I think most front and rear componets are the same as the 4 wheel disc brake version of normal Taurii. The CV joint/shaft is not.
benson
Taiwan
Hi
I am looking for steering gear with tie rod end/
Strut Rod/Stabilizer Bushing/ Strut Upper Bracket & Mounting Plate/ Control Arm Bushing..etc.
actually I want to re-build my suspension system,
because too much noise come somewhere under the
body.
thanks.
Porkchop
The Black Sheep
Virginia
Well i am pretty sure that the rack is the same....the one thing taht you need to make sure of is that if you have VAPS get a VAPS rack, as for the rod ends I am pretty sure they will fit...
the stabilizer bars...maybe, i believe the SLO's are smaller, but you can upgrade to a gen 1/2 stabilizer bar and it will work the same way.
as for the other things I don't think so, but Im sure someone will back me up on this.
