wheel nuts
94mtx
san diego
i just bought a set of mille migila spider rims from toolman in oklahoma and was wondering what wheel nuts i should use, as the rims dont come with some. the factory ones should work fine but i was wondering what other people are running on their shos.
thanks
jon
edmontonsho
Edmonton Alberta
The factory wheel nuts/lock did not fit on my rims, so be careful. It depends how deep and wide the openings are. If they don't fit most wheel stores will have a selection. There should be different choices for different finishes, or you can get something that matches or contrasts. Just make sure to buy one lock for each wheel.
Also, I don't recall what rims they are, but if the lugs are visible, you might as well buy new ones. the factory lugs are most likely discolored.
bmytych
