Wheel locks
JoesSHO
Reality
OK, I've searched, and found conflicting info- I want to pull 2 slicers off at the boneyard, but they've got Ford locks on them. I have seen posts saying 16mm, 18mm, and 19mm and a 21mm 12-point as the socket to pound on to get them off. Can anyone confirm what size I need to buy 2 of tomorrow? I guess I can buy 2 of each, but I'd rather not.
It's 20 degrees- should I take a propane torch to heat them up?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
easiest way I've found is with a chisel, but thats just me, I do them at work with my air hammer. 21-22mm 12pt should work, but a wheel lock removal tool set is the way to go, they are cheap enough to save the hassle.
James
hawkeye18
Sorta cares
Norfolk, VA
I've found that if you tighten the **** out of the remaining 4 sockets, the one with the lock becomes much easier to take off. Worst that can happen? You break a stud. You're not worried about that, so tighten away! Also, a pair of vise grips (Viper grips from lowe's work exceptionally well) and an appropriate breaker bar also work well. My lock nuts were, I believe, 19mm.
