Gentlemen,
A few points regarding Gen I front bearings.
1st. By the time you hear a front bearing it is GONE. The looseness from the worn bearing allows the hub to wobble in the bearing. The wobble does two things, 1) it occurs because of a worn dry bearing which generates heat, 2) the heat and the wobble distorts the hub. (Did you see the pictures a week or so ago of a badly scored hub from wobble?
If and when you press a distorted hub into a new bearing you will distort the bearing and it will have a VERY short life.
Moral of the story, replace the hub and bearing as a unit. The short studs that come with some hubs can be replaced with the studs from the old hub. They will need to be pressed out, and then into the new hub.
Item number 2: If you can afford it, replace both sides at the same time, or within a short time of each other. This is not 100% necessary, but is a good practice.
Item #3: The old hub is pressed out of the bearing. The snap ring is removed and then the bearing is pressed out of the steering knuckle.
NOW READ THIS CAREFULLY: The new bearing is pressed into the streering knuckle, and the snap ring is installed (sometimes the old snapring will fit better than the one supplied with the new bearing. (SDPatt ran into this)
NOW PAY CLOSE ATTENTION: The Bearing, in the steering knuckle, is pressed ONTO the hub. DO NOT PUSH THE HUB INTO THE NEW BEARING.
If you are going to change the studs in the hub, do it before you press the bearing ONTO the hub, it easier that way. rangerj
