Basically i have a nasty whub whub whub coming from my left front tire, it starts at ~15mph and goes till ~90mph. Minor vibration while heading straight, lessens/dissapears when turning left, and increases when turning right... Ive been told that this might be signs that a WB is failing.
I jacked the car up and tried to move the wheel toe in/out and caster in/out and it didn't move caster, but the toe was a bit loose, but I attributed that to a slightly worn innter tie rod... Also, Sway Bar endlink it slightly loose where it connects to the SB, which will be replaced
BUT anyway, even if the wheel does not move/isn't loose, does that totally rule out the WB from the list???? And would the loose Inner TR and the SB Endlink cause this vibration???
<small>[ June 06, 2003, 09:12 PM: Message edited by: Porkchop ]</small>
