what's up with this??!!
MI_SHO
LIVONIA,MI
I noticed today that one of my spark plugs poped out of it's socket! Do I need new wires or cylinder cover gaskets????? There is some oil in the spark plug well but not that much.They look like they orig wires so I will prob replace the in the near future, after i fix all the other stuff(STRUTS)!!!!! thumbs_u
Mr Anonymous
Tire Wall
Presuming you mean that one of your spark plug wire boots disconnected and the actual spark plug itself didn't vacate it's threads, it may have just not been on tightly to start with. Clean out the oil and make sure to reinstall the boot properly (BTW, any chance you're not using the Motorcraft AGSP32PP plugs?).
FWIW, I usually recommend addressing engine issues before spending money on suspension, etc. (unless there is an safety issue that needs immediate attention). A comfortable ride is meaningless if the engine isn't running well.
MI_SHO
LIVONIA,MI
Opps I did mean one of the spark plug wire boots. They are the orig wires,so it prob be best to just get new ones!!
The right rear sturt is pretty much gone,so it prob is a safty issue.THANKS TO THE CRAPPY ROADS IN DETROIT!!!!!
Thanks thumbs_u
BeatDaSHO
Hatboro, Pennsylvania
the boot probably popped off because of the oil entering the plug wells. you need the felpro valve cover gasket set. it includes 2 valve cover gaskets and 6 plug well seals. you should also get the motorcraft wires and the motorcraft agsp32pp spark plugs. gasket set can be found at www.autozone.com and the wires and plugs can be found at www.fordpartsnetwork.com
Greg
