What's next? Need to see 12's!!!
What was your car & track setup for these runs? Launch at 2000 rpm or thereabouts? Downpipes is one option, methanol is another. Race fuel (unleaded) + race tune, maybe.
mybigsho
new york
I went to the track with all intentions of running very low 13.0 12.9.. Had little over 1/4 tank 93 from a quick check, took everything out of trunk except
spare.. The time slip you see is my first run the second run was a 13.14 with a 188 sixty.. Then it went down hill.. The track went away.. I did throw 2 gal of 100
unleaded it did like it.. picked up a 1/2 mile an hour 105.90.. I was launching around 2000 rpm.. I'm going to order some down pipes...
Thanks for the feedback..
2012korn
You must have horrible DA's then. Because you should be able to crack a 12 easily with that. Can you get the 4x+ tune lms offers?
mybigsho
new york
I don't now what the DA was this past Friday but I'm sure it must have been good.. It was 60 and bright blue sky... By the end of the night it was like 45..
Whats the 4x tune?
brucelinc
Minnesota
The 4X tune is for 2010-2012 models. The 2013+ use a different naming system. LMS might have a more aggressive tune for the newer models but it would not be called 4X.
Like 2012korn, I would expect you to be in the 12s if you have the most aggressive version of the tune for the year of your car.
2012korn
Considering there is now an 11 sec sho without meth. You should definitely run faster :)
Mdrew
You have the best tune from LMS without switching to race fuel.
I have same build list as you in my '15 and barely broke 12's last weekend.
Mdrew
It was humid with ano unfavorable DA.
Gonna try this weekend to get deeper in the 12's....suppose to be nice and cool out.
bmytych
