what would this cause?
  • Thread starter bullittcntydescd14
  • Start date
B
bullittcntydescd14
Guest
I have a exahust leak in the cattalitic converter.. what does this problem mess up? gas millage? hessitation?
wood_e
The dude
Ames, IA
I don't think it would really mess anything up.... might leak fumes into the cabin... and be a little loud but nothing in terms of engine problems.
Now if they were clogged you'd have issues...
bflosho
buffalo,ny
I have a 93 and my o2's are ahead of the cats so I didn't NEED to replace the cats when I had a small hole rusted thru but did anyways because I was concerned about lost back pressure and I hated that sound that came w/ the hole. Also I was warned about grit getting in and clogging things up or water and salt getting in and rotting the insides. When I replaced my mufflers a couple of months later they were rattling from debris inside and was told it was probably from my cats rotting and pieces getting blownout and trapped in the stock mufflers... I guess that could cause a restriction and a loss of performance.
WakaShoMan
South Bend, IN
bullittcntydescd14:
Gas mileage will not be affected, especially after you pass out from carbon monoxide fumes filling the passenger cabin.
Fix the cats. Exhaust leaks can be deadly. doh
oh_SHO
Ohio
WakaShoMan:
bullittcntydescd14:
No kidding. Couple of years ago I was drivin' the Cougar in cold weather so I had the windows up to keep warm. Well, I came home that night with the worst headache I've ever had and it lasted a couple of days before it was totally gone. Don't know if the leaky exhaust was what caused the headache but I didn't drive the car again untill I had a new system. mmmmm, flowmasters on a big block... Music to my ears.
