What to use for spark plugs and wires?
SHOYAY
WNY
Aside from stock motorcraft plugs and wires, what have all of you used for plugs and wires on your sho and had good luck with? Thanks for your input and info !
kevinspann
Don't take my advice.
Richmond VA
Autolite double platinum, or fine wire Motorcraft for the plugs. Most sets of wires you find will work fine.
frosho
WOLFMAN
Tyngsboro, MA
The ones on my car right now SUCK at keeping water/debris out of the plug wells. I've had quite a few misfire problems in the last few months because of them. I'll try to remember to check what brand they are after I get out of work.
biker889
Quakertown PA
I use Autolite wires. Identical to OE minus that funny wrap stuff. and motorcraft or autolite plugs
lots of times this happens not because of the wires but because non-Motorcraft plugs are installed. the Motorcraft plugs are designed to a Japanese spec, not a SAE spec, so the non-Motorcraft plugs are too long. this makes the wire end not sit down against the valve cover, therefore it does not seal, therefore you get junk in your plug wells.
DJSHO91
Durham, NC
AC Delco wires with the Motorcraft FW plugs. 20,000+ miles and running great!
frosho
WOLFMAN
Tyngsboro, MA
Hmm interesting. I have Autolite APP3924 plugs in there, maybe that's the problem. I think I may have come up with a fix already, though. I scored some "scrap" expanded PTFE gasket material at work and punched out a few donuts to make a tighter seal between the plug wire "cone" and the valve cover, and it seems to be working so far. Thanks for the info on plugs, though.
SeanMc
NoMoSHO
I had Taylors, and they are trash. Kept having to replace them once a year. James (St. Louis SHO) suggested Autozone Duralast wires, and guess what? They are great, and have a lifetime warranty. For plugs I'm using Motorcraft.
frosho
WOLFMAN
Tyngsboro, MA
I spoke too soon. Misfired all the way in to work today. :doh: Two of my donuts worked, but one didn't.
once the boots have started to short through the water/oil to the head, they will continue to do so under load even after you have cleaned up the mess. so, you will need to replace wires.
thered91
Mountain View CA
I bought mine from o'riellys, there 8mm plopped right in no gaps, and cost a wopping 41 dollars...oh and motorcraft plugs...
