What spark plugs to get
1993MTXSHO
Its a Taurus...
Jersey
Hey guys im doing a 3.2L swap and im going to be putting new plugs in and am wondering what plugs to get. RCM has all of this, will regular plugs work just fine? or to get complete combustion and best gas mileage I should go with some more expensive ones?
32.99- Autolite dbl-platinum spark plugs
OE double-platinum design
24.99- Motorcraft platinum spark plugs
Improved platinum "fine wire" design
16.99- NGK "Standard Series" spark plug set
24.99- NGK "V-Power" spark plug set
29.99- NGK "G-Power" spark plug set
59.99- NGK "Iridium IX" spark plug set
74.99- NGK "Laser Platinum" spark plug set
79.99- NGK "Laser Iridium" spark plug set
Mr Anonymous
Tire Wall
Use some Champion lawnmower plugs.
Is your search button broken or are you going to post a question each time you tighten a bolt too???
USHOMEISHOU
Troublemaker
New Mexico
:lol: Dude, aparently Mr. Anonymous likes screwing with you:nut:
I've been running the NGK "v-power" plugs with no problems at all:thumb:
1993MTXSHO
Its a Taurus...
Jersey
ok i trust motorcraft and autolight, I guess ill go with them, and yeah do you guys know how to tighten the screw the holds the air filter on? do i turn it to the right or left?:rofl: Yes i do use the search button and Im not finding the stuff I want sometimes so i post.
Searching is a good thing
Here is a current topic regarding the choice of plugs for the SHO.
1993MTXSHO
Its a Taurus...
Jersey
USHOMEISHOU said:
:shrug: i don't have a screw holding my air filter on:oogle:
I have a cone filter, its got a hose clamp holding it on which is a screw, thats what i ment by screw. So its counterclockwise guys to tighten right?:rofl:
USHOMEISHOU
Troublemaker
New Mexico
AAAAHH I SEE SAID THE BLIND MAN!:bonk: I still have the stock air box.
but to answer your question either way you turn it, it'll come off eventually:rofl:
1993MTXSHO
Its a Taurus...
Jersey
Howdy_Doody said:
Just to check this out, I did a search for 'spark plugs' and this was the first topic that came up...:shrug:
which is exactly why i posted, I didn't find he real info i needed:thumb:
